Ok, i want to get this problem fixed. It's getting really annoying. If I don't close out all of the open windows in the scanner, then next time I open it up, I get the error in the picture. I can hit continue and everything is ok. I can have every window open when I close the scanner and then open it back up by double clicking on a log and it loads fine with no error. I've went back and forth with support a while ago and we couldn't fix it. I'm currnetly on a new laptop with a new hard drive and a fresh XP Pro install and it still does it. Has anyone else run into this problem and found a cure?
Tim
