I have a 99 Tahoe with a 383 stroker 4l80e swap that I was running using an 0411 pcm with the 02 express 3500 calibration. This thing ran great once I got the calibration close to where I wanted it then Saturday it backfired through the exhaust and died and has not fired again since. So far I've checked for powers and grounds, replaced the cam and crank position sensors, coil and ignition control module with all brand new delphi components, check the distributor phasing which was perfect per the service manual, still no fire. I habe rpm signal on the scanner so I think the crank position sensor is working and I've also verified the pcm has power and grounds can someone please help with figuring this thing out because since my transmission went out in my other truck this is my only transportation
