Results 1 to 7 of 7
Thread: The year 2017CLA45 M133 lock the throttle, kneel and beg God can help me
    Optimum torque monitoring torque I see a slight deviation in this section and the ECU locks the throttle,60-160km/h 8.4s slow!I want to get to 600nm, 2.3bar, without locking the throttle, that would be very fast,
    Tuner outlaw_50's Avatar
    Nov 2020
    United Arab Emirates, AlAin
    196
    what do you mean ECU locks the throttle, I can see from the log that its opening
    Xstages Motorsport
    Tuning inquiries:
    Whatsapp: +971503383340
    Email: xstages.motorsport@gmail.com
    Insta: @xstages.motorsport
    Tiktok: @xstages
    Website: https://www.xstages.com
    The gas pedal is pressed to the end, and the actual throttle opening is very small at
    This log is 0-160 km /H, the gas pedal is pressed to the bottom, and the actual throttle is only 30% open at each shift, which makes me accelerate very slowly. I would love to get me 0-100km/h3 seconds m:崇拜:ore
    Nov 2020
    196
    do you mean that the throttle is closing to 30% between shifts?
    yes
    Yes, sometimes when there is no gear shift, the accelerator pedal will go all the way and the throttle opening will also change
    Nov 2020
    196
    closing between shifts is normal if you dont have TCU Tune
    Xstages Motorsport
    Tuning inquiries:
    Tiktok: @xstages
    Jul 2021
    21
    Hi
    It's limiter. You can get rid of it. I can see, that you have the WG ~32% and boost is almost stock. The M133 boost limiting system are... well... hard to get it .
