I have a newly rebuilt engine and have around 100 miles on it now. Displacement was increased by 10%, made some changes to the calibration to accommodate increase in displacement. Most everything else in the combination has stayed the same and ran very well before the rebuild. Have put enough miles on the engine to start opening it up a little, but when the engine gets to about 85kpa manifold pressure and above, it acts like it's hitting a rev limiter.
Calibration is 2bar OS running speed density. Has a positive displacement supercharger pulled for about 7#.
At one point in the log (05:50:46) Dynamic Airflow is calculating out at 1.78g, which is way off the chart for the spark table. It's at this point that it acts like it's knocking and pulling a ton of timing out. Initially I thought maybe it was blowing spark out, so I regapped plugs. All plugs look good and no signs of detonation on them. I believe it is false knock I'm seeing. Have tried to run down any potential fueling issues I could be having, but it has a really good return style fuel system. Fuel filter was changed, fuel pressure gauge says I have good pressure, fuel pressure regulator is same I had before started experiencing this. Grounds have been replaced.
Have tried added a ton of fuel to see if that fixed it and it doesn't help. Pulled timing and that hasn't helped either. Added timing when we thought it was too conservative. None of those things helped it out. Like I say in the title it acts like it's activating a rev limiter. Engine runs very well everywhere else, idles smooth, cruises nice, doesn't over heat.
Any ideas on where to begin?
20230620 Driving.hpl99 Silverado 6.6SC_Base8 No DFCO.hpt
