It's available in the Table View under PID -> Transmission -> General, but not available in the graph view or for histograms.
How would I go about filtering 4th gear stuff to work on 4th gear load knock???
Is this a bug or not?
2005 Pontiac GTO LS2
MY FQUICK - http://www.fquick.com/cyclone_chris
Mods:
K&N Intake | 18" Staggered TSW Thruxton Setup | Toyo T1-R Tires | Billet Products Short Shifter | Kooks 1-3/4" LT Catted headers | NGK TR55 | Ported Stock Intake Manifold | Corsa Sport Exhaust | Polished T/B | FlowTech Streetsweeper V2 Cam | SLP UD Pulley | 160 Thermostat | LS7 Clutch | 39# Ford Blue Giant Injectors | Scorpion Roller Rockers |
445 RWHP/413 RWTQ
I don't think you can filter by gear & such...never been able to from what I can remember.
Don't see a reason why you wouldn't be able to. You can log the gear you're in. I can see it change accordingly on the Table View 1-2-3-4-5-6 and Neutral.Originally Posted by foff667
Mods:
445 RWHP/413 RWTQ
Here is an image to better explain the issue.
Mods:
445 RWHP/413 RWTQ
If the "Trans Current Gear" PID comes up as 1, 2, 3, 4 then you can filter it using the "[PID#] = 4" as your filter if you wish you can also filter out all the "no knock histogram points" by adding "AND [KR PID HERE] > 0.08"
Always Support Our Troops!
Well, whats the Trans Gear Select PID number?? For some reason it's not listed in the histograms PID listings.Originally Posted by EC_Tune
Mods:
445 RWHP/413 RWTQ
Should be Trans Current Gear.
[PID.4120] is the Trans Current Gear PID if I am not mistaken...
Pacesetter LTs| Flowmaster & Custom 3" ORYPatriot Gold dual springs | Titanium Retainers | CM RodsXER 226/226 585/585 112 | MTI lid| P&P TB & MAF | TBBHurst | !AIR !EGR | Built T56 | 01-02 Slave cyl.'04 GTO A4 Black/Red | Free Mods | 13.2 @ 106 1.9 60' every time
Nothing... doesn't work.Originally Posted by stone
Mods:
445 RWHP/413 RWTQ
I wish I could filter out by gear, but my car doesn't support it
I'm assuming if the car logs gears as mine does, then you should just be able to filter out that specific PID. Unfortunately I do not see it available in the histos.Originally Posted by MeentSS02
Mods:
445 RWHP/413 RWTQ
chris, i exported your log to excel so i could do some by gear histos myself, and no go either, the gear is stuck on 0 in all cells. booo
I can log that PID, but it is meaningless on my car...the PCM has no idea what gear I'm in.Originally Posted by Cyclone Chris
Current Gear only works on Autos, since it has actual "sensors" to monitor what gear it is in. Mostly due to pressures and such, where as M6s you are the shift/pressure/TCC tables. The 2002 ZO6 I recently did always showed 3rd gear during driving sessions (IIRC).
I tend to disagree.... the capability to log gears is there. Take a look at the picture and the thumbnail in this post and you'll see 6th gear.... of course it changes. Attached is the log with gears being logged also... take a look at it.Originally Posted by 12secSS
Mods:
445 RWHP/413 RWTQ
Chris,
Do you know who you got that log from? I'm thinking that maybe they wrote a custom pid that calculates gear ratio from vehicle speed and RPMs.
Tim
That's my log... took it yesterday actually. There is nothing custom about the PID. If you look at the screenshot in post 3, you'll see where it's available at. It may be an LS2 GTO thing. Maybe Chris or Keith can elaborate on this.Originally Posted by bullygoat
I attached the config file... maybe that helps.
Mods:
445 RWHP/413 RWTQ
