I have a 2000 S10 with a 5.3L swapped in. I bought a PCM with a start up tune from CPW. I had made some adjustments but could not fix a couple of small issues. It started, ran & i was driving it. The tune was for a 2005 Silverado 5.3L.
It was suggested to get a more compatible tune for the S10. I was given an OS # 12587603 as a good one to fix the issue.
So this OS # is for a 2004 S10 4.3L & also for a 2004 SSR 5.3L. I segment swapped the 5.3L into this tune. I also mimicked some of the codes setting from the old tune to the new tune.
Now it wont start. So I scanned for code and came up with:
P0315 CPS not learned
P1631 VATS
I set the P0315 to no error reported, I set the VATS control to "none" under editor>system tab> general> security. I also set the P1631 code to "no error reported"
It still won't start. I am uploading the current tune, the old tune & a log file of it cranking but not starting.
Any help is appreciated.
