Results 1 to 6 of 6
Thread: MPVI2+ Will Not Read
    Angry MPVI2+ Will Not Read
    I have a MPVI2+ I bought new and just got around to using.
    It will not read.
    I have installed, uninstalled and reinstalled the drivers and VCM Suite.
    I have restarted my PC many times.
    Cycled KOEO many times.
    Disconnected and reconnected at USB's and OBD port.
    What the heck could it be?
    It'll give the option to write, but not read.
    I can use the scanner fine to log. Jut can't get it to read the tune file on my car!
    2010 Camaro SS 781rwhp
    TKR Stage 4 CTSV 6L90
    Circle D 258mm 3400 3B Pro Series Multi Disk
    Kooks Ceramic LT's & full 3in exhaust
    TFS GenX 255's (Polished PAC .660's and Ti-Retainers)
    TSP VVT 3.2 cam
    Smith Bro's trunnion kit
    AEM X-Series OBDII Wideband Gauges
    FIC ID1300x Injectors
    ZL1 Fuel Pump
    DSX Flex Fuel Kit / Auxiliary Fuel Pump Kit
    MM Camaro 5 Wild
    Holley Tall LS Valve Covers
    NGK Iridium IX #7
    HP Tuners MPVI2+
    ProCharger D1X @ 13psi
    May 2014
    USA
    452
    Is it failing to read, or the it won't even let you click the read button? I read your post as it won't even let you click.... apologizes if this is obvious, but you need to NOT have a tune file open in order for the read button to work/do anything.
    28,282
    click file-close
    You can't read an ecm if you have a file open.
    Quote Originally Posted by aaronc7 View Post
    It doesn't even allow me to click the read button. Only the write works.
    TSP VVT 3.2 cam
    ZL1 Fuel Pump
    MM Camaro 5 Wild
    NGK Iridium IX #7
    HP Tuners MPVI2+
    click file-close
    I did t have a file open.
    But I'll try this anyway.
    click file-close
    Yup... You were right.
    I haven't used this tuning software in so long I forgot what to even do. LOL
    TSP VVT 3.2 cam
    ZL1 Fuel Pump
    MM Camaro 5 Wild
    NGK Iridium IX #7
    HP Tuners MPVI2+
