Hi, I have a Cherokee Chief with a L29 454 & 4l80e, thats had a 0411 swap, in low range, its not changing up gears unless revved above 3000 in each gear.
I have connected c2-16 to earth when in low range & i think its c2-17 with ignition power. I am pretty sure the file is from a 4wd , but not 100% , if someone could check that would be awesome, I have tried some segment swaps from the repository, but not many there , with my os 12212156, 2002 model, the others wont let me do the swap.
So some help please with
Other possible causes
Someone with a file for a 2000 ish Silverado or Suburban that has a 4l80e & is 4WD that has a OS 12212156 or something that is compatible for a segment swap in case mine is not from a 4WD.
I have found a file for a K2500 4wd & done the segment swap, but still not shifting out of 1st when in low range, unless revved above 3000. Works fine in high range.
Any ideas?
