Hi all
I want ask about the AFR target for supercharge
I see some car with 9 AFR some with 8 AFR ... i want to know about best AFR ratio target for supercharge please
Ty all
Hi all
Ty all
Just look at a ZR-1 file.
If we are talking about a fuel with a 14.7 :1 stoich
roughly somewhere between 11.2 and 12.2 just depending on how knock sensitive it is.
Tuner at PCMofnc.com
AFR can get confusing for many when dealing with blends of alcohol with gas… basically target 1.0 lambda driving and I tend to target .78-.80 lambda on boost rigs that’s are port injected
Email Tunes, [email protected]
15 C7 A8 H/C 2.3 Blower/PI
14 Gen 5 Viper
Tune in lambda. .77-.81 under boost. I like to stick to the .77-.79 to be safe.
2013 CTS-V Coupe M6 - 1 7/8" Headers, 3" x-pipe, stock mufflers, Airaid intake w/green filter, ID1050X injectors, DSXtuning flex fuel kit, DMS under hood tank, upgraded pump, 3/4" lines, griptec 2.4" pulley, solid isolator, 100mm idler, reinforced brick, MM mild catch can, AEM 30-0334 wbo2, 600whp/630wtq
would a ctsv with 2.55 pulley and exhaust targeting 12.38 on 20 degrees sound like a recipe to pop a piston ringland lol
14 Gen 5 Viper
