Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
Thread: 2000 k3500 l29 454, nv4500
  1. #21
    Dec 2022
    NE ohio
    19
    log file
  2. #22
    Mar 2022
    Indiana
    2,939
    Ok good trims. Moving to MAF
  3. #23
    Dec 2022
    NE ohio
    19
    here is the log, I forgot to ask if I should have been doing anything different with this part? so I just did the same basic route I have been.
  4. #24
    Mar 2022
    Indiana
    2,939
    You're still clearing LTFT and fuel trims before each log I hope.
    I need more RPM. Try to get to redline a few times with 80% pedal. Lock it into 2nd if you have to. Also go for a longer drive 15-20 min. You're doing a good job varying loads and engine speeds. Just need more spread.
  5. #25
    Dec 2022
    NE ohio
    19
    Yes I am clearing LTFT before each log. also the truck is a manual, I can lock it in any gear, lol
  6. #26
    Mar 2022
    Indiana
    2,939
    Oh yeah lol duh.
  7. #27
    Dec 2022
    NE ohio
    19
    This should have the spread you are needing, got up around 42-4500 a couple of times in third gear.
  8. #28
    Mar 2022
    Indiana
    2,939
    Much better.
    Alright hopefully this is the last one. May take one more though.
  9. #29
    Dec 2022
    NE ohio
    19
    didn't know if I still need some high rpm, so there are a couple in the mix.
  10. #30
    Mar 2022
    Indiana
    2,939
    Here's MAF 4.
    Also, here's a tune setup to where you can take your trip. PE and DFCO is all that's different.
    When you get back we can continue if you'd like.
  11. #31
    Dec 2022
    NE ohio
    19
    I will let you know next week how it feels on the Full file and also will run a log on the MAF file. thank you for your help on this. I am looking forward to seeing how the truck does now that it is dialed in better.
  12. #32
    Dec 2022
    NE ohio
    19
    Just wanted to let you know it will be a bit for the next log. I am now having a fueling issue that started about halfway through the trip. Trying to narrow down what the problem is.
