2004 Silverado 4.8 tire size.hpt23-07-04 17-39-13.hpl2004 Silverado 4.8 Torque management test.hpt23-07-05 08-09-32.hpl
I really don't know what I'm doing when it comes to this software, but I am trying to use this stock truck as a way to learn what all the functions do. I am currently trying to figure out what the issue is with random hot idle misfires and a very pesky knock sensor low voltage code, but other than that, it is a really solid truck that needed some TLC.
In case it comes up, I'll list things I've replaced/done; I have cleaned all the grounds, replaced knock sensors and harness twice (once with used but known good, and again with new ACDelco yesterday.) New intake gaskets, exhaust gaskets and manifold bolts, plugs/wires, cleaned connections at ECM, crank sensor, cam sensor, rebuilt trans, TPS sensor, Coolant temp sensor/harness, fuel pump/regulator, stock 25317628 injectors (have tried a set of cheap aftermarket injectors, then put in another set of known good 25317628s but nothing changed random hot idle misfires.)
I attached the stock tune, and a quick log from yesterday after manifold and intake work. Second tune file is my newbie attempt at better response and torque management reduction, with a quick log going to get gas this morning.
Those of you that have done this for the past 20yrs on these trucks, (if you would, please) can you take a look and let me know if there are things I didn't address but could have, or more importantly, things I did that I shouldn't have? I have no plans of trying to make this thing some kind of hotrod, but it sure acts like more of a V8 regular cab short bed with 3.73s with these changes. I'm just unsure of making this a permanent change considering how much I DONT know at this point.
Thanks for any help or advice!
