Originally Posted by
TMTauto
I recently did a swap on an 03 GMC Sierra. It originally had a 4.3l/4l60e. the motor spun a bearing, luckily my buddy who owns a salvage yard had just bought an 06 Escalade 6.0l/4l65e in, running driving truck, just hit in the drivers door. both vehicles are 2WD so i just did a complete pull out of eng/trans, harness, accessories, fans and radiator. Pretty much plug and play with no mods needed. Pretty sweet. Everything went smoothly except for the guages. The alternator guage works, but the Battery light is on. The fuel gauge is defaulted empty with the light on and the service engine soon light does not come on. Unfortunately I never downloaded the 4.3 ECM calibration. I did have a few 03 truck calibrations to reference. The only I did see different outside the tank capacity was the Primary Volume and Primary Volume Gauge tables were different. On the truck they read 0 on the table and the Escalade had values,so I copied over the tables from the truck to the Escalade. I know 99-02 trucks had a different set up than the 03-07 trucks. I have swapped many clusters on these trucks (we all know how great they are), as long as they fell within those year ranges they worked with no issue. I looked at both the 03 4.3l and the 06 6.0l and both ECMs use the same pinouts for the fuel gauge. The Class 2 data wires are the same. The alternator and all wiring are right out of the Escalade. The ECM and cluster are talking, so I'm sure it has to be something in the ECM. Yes, it did work before and we put a new fuel pump from an 04 up truck to keep the returnless fuel system. Any help would be greatly appreciated. thank you
