Results 1 to 15 of 15
Thread: Why is my tune commanding rich?
    Tuner awest623's Avatar
    Oct 2019
    Pyeongtaek, South Korea
    70
    I was doing some lean cruise tuning today and noticed that the tune is commanding rich (eq~.948) when throttle is approaching or at 0 and decelerating. I've looked through my tune file and can't find any reason why that would be happening. I'm hoping someone with more experience can point out where the error is.
    You can see the issue at timestamps: 01:24:516-01:32:692, 02:25:483-02:30:254, 03:06:181-03:19:006, etc.
    Specs:
    1998 K1500
    L31 (5.7) engine
    P59 Swapped on a 2 BAR OS
    Whipple Supercharger
    43lb Injectors
    Cam, Heads, Headers
    Bunch of other stuff that doesn't relate
    Tune and Log attached below, thanks in advance!
    12JUL2023 600rpm idle-lean cruise.hpt
    23-07-12 17-50-42.hpl
    1998 GMC K1500 Z71
    * L31 350 Vortec
    * AUS 43lb injectors
    * Comp 08-410-8 with 1.6 rockers
    * P59 swap
    * Whipple supercharger
    * JBA headers
    * AFR 190cc heads
    * NV4500 swapped
    * Cal-Trac traction bars
    * 1" blocks, 265/70r17 BF Goodrich KO2s, 17X8.5 ALPHAEQUIPT COMMAND LT
    Oct 2019
    70
    Here's my scanner layout as well, in case anyone wants to use it
    12jul2023.Layout.xml
    1998 GMC K1500 Z71
    * L31 350 Vortec
    * P59 swap
    * JBA headers
    * AFR 190cc heads
    * NV4500 swapped
    Nov 2006
    2,751
    The later Gen 3 trucks would do this if the rear o2's were completely deleted. There is a cat test that can be disabled but not with the current software.
    Tuner at PCMofnc.com
    7,695
    Cat test (or Post O2 test, whichever one it's doing) on Gen 3 can't be disabled with any version!
    Oct 2019
    70
    Interesting. I'll have to look into that more but it makes sense. I just recently did the P59 swap and I'm using a 2005 Mexican truck operating system. I was hoping to eventually get the truck back to some semblance of closed loop with lean cruise.
    1998 GMC K1500 Z71
    * L31 350 Vortec
    * P59 swap
    * JBA headers
    * AFR 190cc heads
    * NV4500 swapped
    Nov 2006
    2,751
    Honestly most people don't even know those test are being performed and its not a huge deal. You could likely get by fine ignoring it.
    Jan 2014
    SoCal
    1,567
    You had suggested before about reinstalling the post O2's and zip tying them up. Do you do a "no reporting" for codes? Or like failing the MAF, first error with no MIL so they fail and end the continuous testing?
    Oct 2019
    70
    Honestly, it's just annoying more than anything. Once I re-enable DFCO it won't make a difference anyways. At this point the only reason I'm not going back to the 0411 PCM is because I don't have an operating system that supports Clutch Transition DFCO. I originally put the P59 in because the operating system supports flex fuel, just to find out that it disables flex fuel when unless you run a 24x crank reluctor.
    1998 GMC K1500 Z71
    * L31 350 Vortec
    * P59 swap
    * JBA headers
    * AFR 190cc heads
    * NV4500 swapped
    Oct 2019
    70
    Quote Originally Posted by TheMechanic View Post
    I might try enabling the codes. I don't believe the post cat O2 wiring is even in the harness anymore.
    1998 GMC K1500 Z71
    * L31 350 Vortec
    * P59 swap
    * JBA headers
    * AFR 190cc heads
    * NV4500 swapped
    7,695
    No, don't re-enable any of the codes. The tests it's running are separate from anything in the DTC list - since it's never been available in any of these PCMs I don't know exactly which one(s) it does. But like the Gen 4s, cat test/post O2 test are their own thing separate from anything else.
    Oct 2019
    70
    Gotcha. Thanks for the information
    1998 GMC K1500 Z71
    * L31 350 Vortec
    * P59 swap
    * JBA headers
    * AFR 190cc heads
    * NV4500 swapped
    Nov 2006
    2,751
    I've heard some people would turn the diagnostics back on but turn the lights of for rear o2's on 04 GTO's (gen3) and it would stop doing this.
    Oct 2019
    70
    Yup, I tried this before he made his replay saying not to. It didn't make a difference. Probably the only way I see around it is to adjust the OLFA ever so slightly lean so it doesn't command stoich and allow the diagnostic test to run. Haven't tried it yet
    1998 GMC K1500 Z71
    * L31 350 Vortec
    * P59 swap
    * JBA headers
    * AFR 190cc heads
    * NV4500 swapped
    7,695
    It will keep commanding rich and then commanding lean to try to get a pass/fail, forever (well, multiple times per drive cycle), in an endless loop. Unless you plug some rear O2s back in. They do not even need to be in the exhaust system, just tied up somewhere out of the way. Then, it will get a result (fail, but that's OK, since the only thing that will do is keep it from trying again).
    I'm not positive, but I believe you can disable/de-pin the heater circuits on the tied-up rear O2s so they don't try to melt everything. These tests it needs to run aren't related to the heaters, I don't think they need to be there.
    Oct 2019
    70
    My truck never came with heated rear o2 sensors anyways. I'll give that a shot sometime. I haven't noticed it commanding lean outside of when I'm in lean cruise.
    1998 GMC K1500 Z71
    * L31 350 Vortec
    * P59 swap
    * JBA headers
    * AFR 190cc heads
    * NV4500 swapped
