Hi all, so I have a 06 GTO with an LSA on it. Long story short, the car likes to run rich, then I modify the VE table and then its very lean. I will post two tunes and two logs accordingly, the first one (tune 13) it runs super fat and the second one (tune 14) is super lean after making some changes, although it progressively got more lean the more I drove it. Second VE table isn't pretty but more so for demonstration how this car has a mind of its own. Fuel Injector Clinic 1000 injectors, LS3 TB, its on a SD tune, more info is in the tunes calibration details. Something to note although I am confident it doesn't make a difference, the MAP I believe is on its way out. At times it reads 225kpa and wont run, have to tap it then its back to normal. But when it works, it works. Please can someone see if I am missing something but I am not understanding.
Base Tune #13.hptBase Tune #14.hptTune 13 log.hplTune 14 log.hpl
