Results 1 to 3 of 3
Thread: pro link + no get data from gauge !!
    i have problem from 2 week ago and i do so many search to can know what is problem but i didn't know it
    WB ( AEM 30-0334 ) keep read in scanner 8.2 - 9.0 AFR so fast like its hanging between these numbers
    in gauge read normal 14.7 - 15.3 AFR ... but in scanner no get this data .. i change pro link+ already and i got new one .. i get same problem
    it could be a electric problem ?? idk
    anyone can help .. plz ?
    Jan 2014
    SoCal
    1,851
    https://youtu.be/ozJz-pNFCuo
    For those using AEM 30-0334 with HPT, when adding channels and searching using "WB", HPT provides channels for 03-03xx WBs, not channels for 03-0334 OBd2 WB's. YOu have to follow channel hierarchy as shown below..
    One thing that confuses a lot of people is the channel naming convention.
    In the add channels window, there is a section:
    Code:
    External Inputs
    |_AEM
    |_X-series UEGO (30-03xx)
    |_ WB EQ Ratio 1
    WB EQ Ratio 2
    etc. Which LOOKS like it should be the exact right stuff. BUT, IT IS NOT! That is for the AEM 30-0300/0310, when connected via the ProLink.
    The correct channels to add are in this section:
    Code:
    Engine
    |_Fuel
    |_Open & Closed Loop
    |_Oxygen Sensors
    |_ 12 WB EQ Ratio 1 (SAE)
    12 WB EQ Ratio 2 (SAE)
    12 WB EQ Ratio 3 (SAE)
    12 WB EQ Ratio 4 (SAE)
    etc. which one will depend on which PID value you selected in the 30-0334 setup UI ( On the gauge )
    i use pro link+
    so i open
    external inputs
    mpvi2+
    pro link +
    mpvi2 PL A/D input 1 ( red )
    this what i was use .. then it would not work anymore
    before i use transform i see volts 0.35v - 0.60 v .. is that normal or no ??
