Results 1 to 15 of 15
Thread: 16 Silverado 1500 boggs down off the line
    Apr 2023
    9
    VVE step 18.hptvve step 18.hpl
    the truck doesn't want to move from a stop. acceleration isn't great once you get it moving. Used this thread as a guide... still no luck
    https://forum.hptuners.com/showthrea...out-of-low-end
    can't figure out what's up
    16 Silverado 1500 LT L83
    BTR stage 2 cam 210/223 .540"/.540", 111LSA,14% fuel lobe
    BTR springs
    DOD deleted
    3rd cat delete
    resonator & 3rd muffler delete
    K&N 63-3082
    Nov 2006
    2,742
    What are the VVT settings supposed to be for that cam? There is a lot of cam advance off idle. This could be the problem.
    Be careful how you handle VVE with the cam moving that much.
    Tuner at PCMofnc.com
    Apr 2023
    9
    I suspect this is the issue but I am not sure how to correct it...
    I have a phaser limiter in which maxes out at 20*
    I update my Camshaft> desired cam angle to max out at 20 per the limiter. I haven't done anything with VVT.
    when I go to EDIT>Virtual torque I can seem to edit any of the table in there...
    I made some edits to the PE menu to try to correct the timing on the camHigh Baro.PNGLow Baro.PNGMed Baro.PNGPE Menu Now VS Stock.PNG
    Nov 2006
    2,742
    Tuning Addict
    Jan 2015
    6,804
    What Alvin is referring to is Variable Valve Timing. Brians Cams always come with cam cards that states somewhat on where to set the cam settings to. Won't be perfect, but will be really close for you. Look at the target angle in this one... It should also be noted if you want mpg's that you can run some timing in the lower rpms and lower loads - just keep it below what peak angle is calling for in the card. It will get better mpg above that, but will really lag on power.
    ~Greg Huggins~
    Apr 2023
    9
    where should this be entered? and that is my exact cam card GHuggins
    Apr 2023
    9
    the only place this makes sense to me is the WOT desired angle base maybe VM offset it this correct?
    Tuning Addict
    Jan 2015
    6,804
    Low, Medium and high Baro tables plus the wot base table. Those are the 4 tables where you need to fix this.
    ~Greg Huggins~
    Apr 2023
    9
    I did the low, med, & high baro tables pic in earlier response. I just did WOT, I also disabled "Enable conditions", 0ed out corrections, and set ramp rate to 1 she still pulls loads of timing at idle. New log. Just pulled up and down my drive way. Pulls off from stop much better but still feels "squishy".
    Is this thing ready to try and tune VVE?
    vve step 19.hplVVE step 19.hpt
    Tuning Addict
    Jan 2015
    6,804
    Low, Med and High need to be fixed. Either multiply by .25 or do like the cam card.
    ~Greg Huggins~
    Apr 2023
    9
    still pulling tons of timing at idle. she will die if I snap the throttle. I probably need to lower vvt in the lower rpm range? but I can never get the changes to enter...
    I unlink tables and try to go one by one but the numbers don't change what am I doing wrong?
    anyways log, tune, and baro maps attached.
    Drove up and down driveway
    VVE step 21.hpl
    VVE step 21.hpt
    I am trying to learn how to do this myself so I really appreciate everyone?s help
    UPDATE:
    I forgot to update my external load table after reloading a stock copy of the table. Now the idle at start seems great but after a bit the idle got choppy again and pulling timing.... Newest log below
    Attachment 134608
    Last edited by 16L86; 07-18-2023 at 11:44 AM. Reason: Update with a thank you ��/ new tune file and issue
    Apr 2023
    9
    I also did follow the access steps listed on this thread for LAC
    https://forum.hptuners.com/showthrea...-Torque-broken
    Tuning Addict
    Jan 2015
    6,804
    Make all the baro tables the same. OR since you have to do it this way anyway - 0 them out and dial in your 0 cam VVE table, then put values back in and dial in your cam movement.
    ~Greg Huggins~
    Aren?t the older btr stage cams supposed to be locked to 0?
    Tuning Addict
    Jan 2015
    6,804
    Lose A LOT with them 0ed. VE table once dialed in kind of illustrates this. They dive off up top and lose a lot of fuel economy (3 to 4mpg's) down low if you don't dial that part in too.
    ~Greg Huggins~
