Results 1 to 3 of 3
Thread: what mechanical part effect cylinder air mass cyl/g
    what is effect cylinder airmass
    what mechanical part effect cylinder air mass cyl/g ??
    i up VE and MAF still give me same 0.67 g nothing more
    i increase spark 4 degree too ... and still same
    i up flow rate too .. from 38 lb\h to 42 lb\h
    so i think my issue in mechanical things
    fuel pump if weak can effect ??
    i use intake 6.2 L with stock injector 42 lb\ h
    TB 92mm
    head 6.2L and block 6.0 L
    ragulator 58 psi when i do WOT drop to 25 psi
    is that effect cylinder airmass ?? or no ?
    13,576
    Cylinder airmass is measuring just that, the air.
    Make the engine more efficient and the number will change.
    what to do more ... i make new big cam still same ...
    if u can help with some opinion plz
