Results 1 to 14 of 14
Thread: Can't Log LTFT or STFT
    When I load VCM Scanner It shows the LTFT & STFT but says not supported and disappears when you connect to ECM. Its a 2006 E40 ECM.
    Advanced Tuner PGA2B's Avatar
    Nov 2004
    St. Louis, MO
    475
    Have you repolled for supported parameter's?
    2013 OBM A6 CTS-V Coupe
    Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
    2006 Black Raven STS-V (Traded In)
    Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
    7,802
    ST+LT works just fine on my 2006 E40 ECM.
    Oct 2019
    285
    Are you in advanced?
    7,802
    The scanner has basic/advanced modes?
    Oct 2019
    285
    Oh stupid me. I wasnt paying attention.
    You're a tuning god Blindsquirrel.
    7,802
    No, I thought I might be missing something.
    Jul 2023
    Michigan
    12
    After you have connected to the ECM don't start logging and go into your payload section and try to reinsert your STFT/LTFT.. when you switch vehicles in the scanner it will try to pull all the original payloads you had previously pulled up and will tell you not supported if the payload tag from module to module is not the same, unless you were using an SAE payload possibly. If that doesn't work make sure all your drivers/software are up to date from HP
    Advanced Tuner Josue Galban's Avatar
    Jan 2023
    Venezuela
    205
    hesitate for a moment lmao
    Jan 2023
    Venezuela
    205
    Quote Originally Posted by jhbau1000 View Post
    and are you reading STFT and LTFT??
    both work perfectly. I am referring to each
    Sorry guys I've been very busy. I will give you suggestions a try this weekend.
    Re-Polling seemed to work. I can see them now. Thanks.
    Nov 2004
    St. Louis, MO
    475
    Glad you got it figured out!
    Jan 2023
    Venezuela
    205
    re-polling seemed to work. I can see them now. Thanks.
    great to hear thattt
