When I load VCM Scanner It shows the LTFT & STFT but says not supported and disappears when you connect to ECM. Its a 2006 E40 ECM.
Have you repolled for supported parameter's?
2013 OBM A6 CTS-V Coupe
Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
2006 Black Raven STS-V (Traded In)
Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
ST+LT works just fine on my 2006 E40 ECM.
Are you in advanced?
The scanner has basic/advanced modes?
No, I thought I might be missing something.
After you have connected to the ECM don't start logging and go into your payload section and try to reinsert your STFT/LTFT.. when you switch vehicles in the scanner it will try to pull all the original payloads you had previously pulled up and will tell you not supported if the payload tag from module to module is not the same, unless you were using an SAE payload possibly. If that doesn't work make sure all your drivers/software are up to date from HP
Sorry guys I've been very busy. I will give you suggestions a try this weekend.
Re-Polling seemed to work. I can see them now. Thanks.
Glad you got it figured out!
