Results 1 to 5 of 5
Thread: AEM wideband intermittently showing in VCM Scanner
    Jun 2023
    4
    Hello everyone, first post here and first time tuner. Just recently finished a LQ9/4l80e swap into an OBS Chevy and am ready to start tuning however the AEM wideband I got (30-0334) is not ALWAYS showing as a channel in VCM scanner when I start to record the log. I've converted it to serial data because it came with the OBD port for CAN, but my truck and ECU do not support CAN. I've played around with the PID and settings in the actual gauge and am still having issues. I just got it to work for one session but as soon as I cycled the key and tried again, it doesn't show. I've done some searching here on the forum and can't really find any solid information. I would greatly appreciate any help or any directions on what to try. Thank you!
    I've added the channel in VCM Scanner as follows:
    External Inputs>Serial Port>AEM>AEM AFR
    Transform>Parameter>AEM-4110
    Jun 2023
    4
    I did some more research this evening; I found more info when searching the whole HPT forum instead of just the Gen III forum (sorry it's been many years since I've used an actual forum) I came across a user that posted this link which didn't completely solve the issue. However, the actual fix I've discovered is I need to boot-up my tuning laptop WITH my MPVi3 and serial port cable already hooked up. Hopefully this will help any others in the future.
    Apr 2019
    Parts store
    476
    Are you using Windows 11?
    You say it works if plugged in and restart? Good to know. I have not made the upgrade to Win 11 yet because of the issues I hear. I use the prolink cable and have not had any issues.
    Jan 2014
    SoCal
    1,562
    Quote Originally Posted by Hondaeater View Post
    I have been using 11 pro for about a year and a half without issues. Even run it on VMware without issues. What issues are you hearing about?
    Apr 2019
    Parts store
    476
    Quote Originally Posted by TheMechanic View Post
    Are you using the Serial to USB adapters in Win 11 without any issues? IDK maybe the 11 Pro version has better driver support for that connection? The cable gets "lost" which has been an issue for several people, but I use the Prolink and not EGR or AC channel inputs.
