Results 1 to 8 of 8
Thread: NGC3 CAN Low speed cruise issues.
    Feb 2020
    Central Texas
    12
    Dodge LX Hemi Low speed cruise issues.
    I have a weird issue when cruising at low speeds (30 to 40 mph) and light throttle. I get this slight cyclical surge that I feel in the car and hear in the exhaust. I've been working on my idle tuning using 06300SRT8's write up with OK results, and my VE tables are in decent shape. I have a feeling that there is some table or torque setting that I'm overlooking or not finding the info on how to adjust it that may be the cause. I also have a sneaking suspicion that the little bit of occasional idle surge I have left may be related. I have noticed that while cruising in this problem area that my timing will jump up a couple degrees each time i get the surge. If I crowd the throttle just a little bit or get more of a load on the engine it will smooth out... but as soon as I am just maintaining low speed it starts again. My passengers look like they are softly jamming out to a slow song in their heads. Not good. Otherwise, the car makes power and runs good. My setup: 2005 Chrysler 300C, 5.7L bored .75mm over with KB piston, Comp HRT stage 1 cam (216/222, .500/.495 lift, 113 LSA), long tube headers, Flowmaster 3" cat back system, no cats. Base PT and WOT timing is stock with 2 degrees added, 1 more in the hwy cruising area, but they still need a little work. I've attached my current file and a log I took on my drive home from work. Any help or ideas would be greatly appreciated. BTW, I tune lots of LS, this is my first Mopar.idleTrial07.hplCamIdleTune09.hpt
    Your fuel trims look way off to me, if you watch them, they jump around too much and rather large amounts. Personally, I would work on smoothing out fueling within 5% on each bank then see if your issue gets fixed or better. I also noticed on your tune you don't have a parameter for 02 sensor delay. From what I have learned and had other tuners adjust in the past, the 02-sensor delay helps smooth out the fueling since you moved the 02 sensors further from their original location. When I added to the delay it helped smooth out my surge issues at low speeds, this may help you. Another professional tuner may jump in and correct me on this is im wrong, but I fairly certain you want the fuel trims to be as smooth and straight as possible.
    Feb 2020
    Central Texas
    12
    I saw a little info on that. I will see if I can find out how to do it. It's at least a place to look. Thanks for the tip!
    Advanced Tuner rays04gtx's Avatar
    Oct 2021
    Allentown PA
    363
    Couple things,
    1) Start logging Throttle Voltage ,
    2) most of your issue is in Engine>Torque Model>Loss>table 12882.
    See post https://forum.hptuners.com/showthrea...l=1#post691784
    there's few other tricks to make it go away , but 1st start at table 12882.
    62 Biscayne 425/409 SS/D stock class car 10.60s
    66 Dart 426CIG3 8.60@171 2750lbs Naturally asperated
    04 Ram All Alum , 468Ci G3 10.50s @4800 lbs Naturally asperated
    04 Rumble Bee, built 6.1 ,4000lbs 10.48 @ 129s MPH. Naturally asperated
    05 Rumble Stock 5.7, 3.92s TUNE ONLY 13.94@98mph
    Feb 2020
    Central Texas
    12
    Ah. I read that thread but missed the part about adjusting friction loss for the area I'm having trouble in while driving. I have been tinkering with that for the idle. Still not perfect, but getting close. I have problems when I crank the car after it sits. It'll die while I'm backing out of my spot. Once it's been running a bit, I have almost no issues. Maybe an ect adder... hey thanks for the advice!
    Feb 2020
    Central Texas
    12
    Yeah, no way to adjust o2 delay on this pcm that I can find.
    Advanced Tuner PurpleRam's Avatar
    Aug 2017
    Quakertown PA
    504
    Quote Originally Posted by briglicon View Post
    There is but it’s not the same as Gpec
    04 RAMGTX........ 8.82@154mph 392Ci G3Hemi 3250lbs 2.6HP/Ci Naturally Aspirated
    05 RAMGTxtreme 9:45@142mph 426Ci G3Hemi 4000lbs 2.2HP/Ci Naturally Aspirated
    05 Rumble Bee 13.29@101mph STOCK 5.7l , Just a tune, still runs OEM airbox
    09 Challenger Drag Pak 8.65@160mph 426Ci G3hemi 3650lbs 2.4HP/Ci Naturally Aspirated
    G3 Hemi Videos
    https://www.youtube.com/channel/UClS...5mXdDR5sOxs10Q
    Nov 2024
    DE
    5
    how do you adjust o2 delay on a NGC3 with hpt? I cant find anything
