Results 1 to 6 of 6
Thread: Got a Questions about maybe False Knock?
    Feb 2006
    3
    Hey guys!
    Im not new to HP, just to Nitrous Tuning..
    HOWEVER, this is not a nitrous related question...
    I hooked up the VCM scanner to my 2000 Camaro, and I was seeing A TON of knock at just blipping the throttle..
    It was showing inbetween 4-9.5* of KR.. I took the car to WOT and NO KR. I preceded to Shot the DRY 100 shot of nitrous and got NO KR....
    I turned the Timing down to 7.5 ABSOLUTE (I know its low and not correct) and then turned the AFR 11.7 and STILL GOT 4-6* of knock on NO nitrous, just at the little thorttle blips...
    Is it possible Im experience False Knock?? I cant decided whether to step it up to the 150, but I dont even want to shoot the 100 right now until I get this figured out.......
    Under 100 Shot at the change between 1-2 gear (A4) I got like 3*.. So i let out really quick...
    ALSO I descreened the MAF for the DRY shot.... Could it be possible its that?
    If it is the MAF what should i do.....
    Feb 2006
    3
    Any responses woul dbe appreciated!
    2000 Camaro Z28
    HSW Nitrous Kit (150)
    2001 Camaro Z28
    (Heads, Cam, Stall, STS Kit)
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    yes it very well could be false knock.
    Feb 2006
    3
    I was thinking I would hear 10* KR
    2000 Camaro Z28
    2001 Camaro Z28
    Advanced Tuner devildog9999's Avatar
    Feb 2005
    Niagara Falls, NY, USA
    354
    False KR is actually very plauseable. The harmonics of the KR sensors are good, but not perfect.
    Regal GS Site Owner / HPT Moderator / FTV6 Mod
    Apr 2003
    Almost 2000 feet.
    7,876
    If you have forged pistons (I hope you do with N2O ) and they are a little "loose" in the bore you could be picking up a bit of piston slap. If so, just turn the Knock Total Gain values up a bit at idle RPM & MAP and just above there.
    Always Support Our Troops!
