I am working on my base tune for my swap project. Have a mild build 3gen 5.3 with 10.6.1 CR with new 2004 ZO6 cam. I am going to be running the 4th Gen TBSS intake with DBW 90 mm throttle body. I am using a 2004 GMC Yukon Base map. Did a segment swap ( same operating system ) with a 2004 ZO6 Corvette changed engine type to 5.3 change cylinder volume to the correct volume for the 5.3. now my question is in the idle tab under airflow. I already changed the ECT area scaler to match up to the 90 mm throttle body (0.0192) My question is is there anything else under the airflow tab or any other tab I need to change for this intake and throttle body to work correctly.
