Thread: Infered MAP values
    Jun 2023
    7
    Infered MAP values
    This is the stock file from my truck with SOTF enabled, any reason why my inffered map shows such low values? Checked the non SOTF read off the truck and same values minus the SOTF slots. Is there a factor wrong or something? Truck has the latest flash from FDJS done yesterday.
    Jun 2018
    Albuquerque New Mexico
    467
    No that's how it is supposed to be. Nothing is wrong and that is not really MAP, but rather boost or pressure above atmosphere. Which is why it's barley above 0 at lower rpm,mg/stroke.
    Jun 2023
    7
    I understand its not really MAP, but I have never seen a file factor Baro into a MAP value(But I am a little muddy on this inffered map I'm guessing its purley inferred off the MAF and IAT or something). I had them in PSI for the screen shot and because this truck has a PSI Gauge so I took it for a rip to make notes. This truck hits 25 PSIG above baro at WOT and will regularly be 7-15 PSIG during normal driving. According the that table I should be seeing 1.65~10.8 PSIG under the same conditions.
    Jun 2018
    467
    View it more like a Minimum table, instead of a desired boost table.
