Spark quits intermittently
Recently I swapped my VVT cam for a locked cam. Cam Motion 212/220 112 lsa. I ordered and installed the nonVVT cover and installed the cam. After disabling VVT parameters as per Goat Rope Garage and I started tuning. Just with LTFTs as I don't have a wide band. I've noticed the truck will cut out almost as if it shut off then immediately come back. I'm seeing spark go to zero when this happens via the scan file. I used blue locktite on both the cam plate and ARP cam bolts and torqued to spec. I first noticed this on July 14th and it went away. it has come back a couple of times since then but today the bucking started really getting bad. Anyone have any ides where I should be looking?
Post your tune so people can look at your parameters and give your help !!!
It might take me a while to do that. My laptop isn?t wifi enabled.
