This seems to be a fairly common issue when tuning a trans. I've been through CoolAid's guide on trans tuning and I've tried using BlueCat's numbers as well. I've even tried zeroing out the shift MPH and RPM as some suggest, but still no luck. I've tried going back to completely stock numbers as well and still no dice on 2-3 shift. It always hits the rev limiter. This is a built trans with a 2800 converter in an 01 RCSB truck with 3.73 gears, 31.6" tire. 5.7 with Truck Norris cam. The mph is within a couple MPH according to GPS.
What am I missing?
Tune and log file attached.
Trans Rev4 no 2-3 shift.hpl
New Trans Strategy Rev.1 - VE Update.4 E85 Lowered trans shift mph and rpm.hpt
