Results 1 to 5 of 5
Thread: 2015 Cadillac Escalade Stalling, Surging and will not start without throttle BTR Cam
    Nov 2022
    3
    Question 2015 Cadillac Escalade Stalling, Surging and will not start without throttle BTR Cam
    To begin this off I am entirely new to gen V tuning, I am very green with most of this torque based tuning so I apologize if some of my tables look like they have been on the beaches of Normandy. I've mostly worked with Gen III cars and recently a customer brought me this escalade with a DOD failure, So I fixed the issues and installed a BTR Stage 3 Truck Cam and it drives fine but it will not start without giving any throttle input . Most of the time it is pretty difficult to get started, once started it will idle for 20-45 seconds then it will start surging until it stalls unless put in gear. it will occasionally stall at low speeds and almost always after heavy breaking. I have changed just about every parameter I Can and nothing seems to fix it other than removing the vacuum line to the valley cover, Once that vacuum line is removed it runs fine. help would be appreciated. I will attach 2 datalogs and the tune along with a stock tune.2015 Escalade l86 BTR Stage 3 Truck cam idle Surge, Stall and no start without throttle.hpt2015 escalade btr stg3 2.hpl2015 Escalade l86 BTR Stage 3 Truck cam idle Surge, Stall and no start without throttle.hpl
    Tuning Addict
    6,802
    Cranking airflow and torque - last column is used as braf. Prior columns used as startup and braf for rpm settle. You also have split/clo...
    ~Greg Huggins~
    Nov 2022
    3
    Thanks I will Modify those values tomorrow morning, Hopefully that will fix the starting issues. Hopefully I can find a way to fix the stalling and surging issue, but I don't believe these values should have any effect on those two issues. Then again this is my first dive into this platform thanks for your assistance and help.
    Nov 2022
    3
    That fixed my startup issue and i was able to get it to not completely stall in park. now it will idle fine for about 10-20 seconds then throw itself into a pretty bad surge and it still randomly wants to stall going down the road after you let off the throttle after acceleration. Escalade 3.hpl2015 Escalade l86 BTR Stage 3 Truck cam surge,moving stall.hpt
    565
    Any progress here?
