Results 1 to 2 of 2
Thread: Help! 2008 Yukon Hybrid DOD Delete Cam swap
    Aug 2023
    MPLS,MN
    2
    I'm new to this forum and I need quick accurate advice regarding DOD delete and new cam into 2008 6.0l Hybrid. I recently diagnosed my GMC Yukon Hybrid with a bad lifter. So I tore it down and have the heads at the shop getting valve job now, I'm just about to install the new cam and lifters so realizing I will need to tune it I went online here to investigate. What I've found here so far is troubling to say the least. Apparently HPT is very limited at best regarding the tuning capability of the Hybrids. I am planning on changing the cam yet today but thought I'd better be sure HPT will be able to access the fuel tables, so I can tune it. Does anyone have experience or knowledge regarding the Hybrids? I would greatly appreciate any info that may help me before I install the new cam and find I am stuck, thanks!
    did you end up doing the cam swap?
