Originally Posted by
aaronc7
Give this a shot. I copied over the injector data from a 01-04 file. Quick glance, the injector flow rate is slightly higher than your x1.08 file, and the voltage offset table values are generally 0.1-0.2 lower than what's in your stock table. Both will result in shorter injector pulsewidth = increase your negative fuel trims. So this in itself will get fuel trims closer to 0 and will help.
This might be "good enough" but I'd get a good long datalog to confirm fuel trims are close in all operating regions. Can fine tune if you want to, but might not be needed.
