Results 1 to 4 of 4
Thread: 6.4 speedometer
    Apr 2023
    Hammond WI
    13
    6.4 speedometer
    Does anyone know how to make the Speedo read correctly?
    I change the VSS for the ECM under the speedo tab and it doesn?t make a difference.
    Sep 2021
    34
    In the 6.7's, you have to use Forscan and program the BCM for tire size. The rotations per mile is limited to about a 35" tire. I'm guessing it's similar on the 6.4 trucks.
    https://forscan.org/forum/viewtopic.php?t=15994
    Apr 2023
    Hammond WI
    13
    Thank you for the help, I did find it in FORscan, but for the 6.4 trucks it?s in the ABS module.
    However it would not let me change the current tire size, when I go to implement the change it gives me some weird error message saying the data is not compatible or something to that effect.
    Do you think if the tire rev/mile setting in the ABS module is outside of the min/max tire rev/mile setting in the ECM file under the speedo tab it could be causing this?
    May 2015
    45
    1999 chevy suburban 7.4l on 40's
    2006 chevy 2500hd duramax
    2004 chevy trailblazer wife's wheeler
    1999 ford f250 7.3l super duty
    2008 ford f350 6.4l super duty
    1994 chevy s10 4.3 vortech heads w/ tbi intake stock plan to bag one day
    2010 bmw 535xi wife's DD
