Page 9 of 10 FirstFirst ... 5678910 LastLast
Results 161 to 180 of 194
Thread: What is dynamic airflow
  1. #161
    Mar 2022
    Indiana
    2,935
    whilst you guys are figuring the filters out, i thought i'd have a crack at the zone edit tool. cringer, i'll hand the source to you when i'm done.
    Attachment 136124
    This is a great thread. It's fun working together on all this stuff.
  2. #162
    Tuning Addict
    6,802
    You know what. 4th gen and using sae. Going to need to change that to 78ish I would think?
  3. #163
    Aug 2021
    842
    You guys are really switched on! I just wanted to say that I appreciate all of you working together on this to improve the community! From the agreements to the disagreements, explanations, tweaks here and there, "dumbing it down" etc. etc. I feel that there is so much knowledge, information and experience in this thread, that it will be a "go to" for years to come! Thanks to all who are involved! This is awesome info and great work!
  4. #164
    Mar 2022
    Indiana
    2,935
    Not sure. Whatever the throttle says at full pedal the back off a few percent.
  5. #165
    Tuning Addict
    6,802
    It was my fault. After inputting the new filter into the scanner I guess I didn't save the new layout and then when I copied the filter and put it into the 4th gen layout this morning the new throttle settings weren't there and I didn't notice, so you can guess it from there. It is good to know though when SAE pids are used to change the settings for the lower readings on the 4th gens...
    ~Greg Huggins~
  6. #166
    Oct 2014
    Moscow, Russia
    198
    Just want to remind you guys, there are three different TPS PID types - area, position and opening. Keep in mind that you can log TPS PID different from others. This can lead to filter working fine for one is not working for other.
    You have to synchronize somehow what PIDs are you logging.
    2011 Cadillac Escalade L94 w/LS3 valves and valve springs
  7. #167
    Tuning Addict
    6,802
    ^^^^ Yes, thank you for putting more clarity into what I was hinting at, but obviously not correctly or in full clarity
    ~Greg Huggins~
  8. #168
    Here's what I mean. This is a clip from your log, GHuggins.
    Attachment 136119
    Comparison of Modified filter with your TPS>95 to account for WOT (WOT TRUE clearly seen at two locations)...
    Code:
    ABS([50040.71]-[50040.71.shift(-10)]) < ([50040.71]/[50040.71.shift(-10)])*0.1 & ABS([2311.71]-[2311.71.shift(-10)]) < ([2311.71]/[2311.71.shift(-10)])*0.1 OR [50090.156] > 95
    ...to a TPS filter (which I assume is a typical TPS filter format):
    Code:
    (abs([50090.156.slope(1500)])+abs([50090.156.slope(-500)]))<2
    Modified filter allows for not just more data but more varied data to be collected. It also rejects some points of what would be considered stable in the TPS filter where airflow is in fact not steady state.
    I may be completely off, but if I'm understanding this correctly(likely not), the modified filter(great work Sirius) 'should' be the only one necessary when applied to the simultaneous method in Cringers post for :
    https://forum.hptuners.com/showthrea...t=simultaneous
    The modified filter leaves us with presumably good steady state data (for CL MAF/VVE and PE) all the way into PE?
  9. #169
    Tuning Addict
    6,802
    Cringer's formulas have been reworked and cleaned up - the corrected ones are in the last couple of pages, but I can confirm the filters are working great. However the math equation for OL has something up with it - I haven't gone through it yet - most likely something that changed from me swapping from layout to layout cause it was working just fine. I've been having problems with the layouts just changing for some unknown reason on their own.
    If you are using the filter on really big hp builds it struggles and requires multiple passes to show numbers for some reason even though I don't have an average function turned on. Other than that no problems.
    I will say using the dynamic will very quickly show how much the airmass calcs were off. I've seen 30% lean on some fifth gen ZL's that should be making in the 900+ hp range.
    ~Greg Huggins~
  10. #170
    Mar 2022
    Indiana
    2,935
    Quote Originally Posted by cpd004 View Post
    The modified filter leaves us with good steady state data (for CL MAF/VVE and PE) all the way into PE?
    It only replaces the TPS filter, which has the 50090.156 terms. I asked Cringer the purpose of the other parts, but he hasn't gotten back with me on that. I'm not sure what function they perform.
  11. #171
    The modified filter filters out transients during steady state except for when <95? So it would effectively replace the filters in the original thread including CL/PE, correct?
  12. #172
    Tuning Addict
    6,802
    Yes.
    I also confirmed my layout had gotten changed causing my ol one to not read. Now I need to figure out what changed on my 4th gen layout - it's taking about 4 minutes to open logs now - guess I'll just delete out the tables I don't use that much. All this started happening after adding in some new tables for torque modeling. Guess I may be bogging the computer too much and it's loosing some of it's save profiles - only thing I can think of.
    ~Greg Huggins~
  13. #173
    Thank you Greg, Sirius and Cringer. Hoping this thread continues.
    Good luck on getting scanner working correctly.
  14. #174
    Tuning Addict
    6,802
    All credit to Sirius and Cringer on this plus all of the patents and explanations on how it works. I only did some of the big build test for Sirius to do some filter reworking.
    ~Greg Huggins~
  15. #175
    Mar 2022
    Indiana
    2,935
    If someone like you finds use with all this then that's credit enough
  16. #176
    Quote Originally Posted by verlon View Post
    Can you please elaborate on how to go about synchronizing? Just to understand this, are you saying using all of them together somehow show the same data which is actual % open? There are many TPS PIDS to choose from. In my case, I don't see 50090.
  17. #177
    Oct 2014
    Moscow, Russia
    198
    Log all TPS PIDs and try to group them. You will get 2 or 3 groups with almost equal values. 3rd group (actually single PID) will be opening, but it can be absent.
    With a slightly pressed pedal the lowest value will be area, next will be position and the highest will be opening.
    Gen4 and Gen5 Dynamic Airflow uses Area as TPS in the patent
    https://patents.google.com/patent/US20050060084A1/en
  18. #178
    Jul 2018
    42
    Kind of a basis of understanding question. I have gen 3 with a blower added so wrong forum but seems applicable. Sirius mentioned a formula he was going to apply to his gen 3 SD so thought I’d look at this. If I am reading this correctly, that filter can be used to filter transients on say an afr error table correct? My plans shift from trying to tune the entire truck open loop, before tuning fuel trims back on, to trying to tune non boost situations with fuel trims and just boost with the wideband. If using the fuel trims, can this be effectively applied even to a stft+ltft graph to the same effect? Or is it even necessary? Given PE is also entered earlier due to boost I was going to try modifying the TPS portion to use the fuel trim codes as well.
  19. #179
    Mar 2022
    Indiana
    2,935
    I've know that on at least one Gen 3 I've tried there is no Volumetric Efficiency Airflow channel. If you can't use that then the MAP sensor alone will be a reasonable approximation. TPS filter not needed.
    Code:
    ABS([50030.91]-[50030.91.shift(-10)]) < ([50030.91]/[50030.91.shift(-10)])*0.1
  20. #180
    Aug 2021
    842
    I think so. Add OR TPS>95
    Code:
    Looks like this:
    Attachment 136117
    Is that what you wanted?
    Will this work with a traditional VE table or is it VVE specific?
