Results 1 to 5 of 5
Thread: Old school vs New school
    May 2023
    Delaware
    60
    Is there any more risk writing tunes or files in with an MPVI1 vs the newer MPVI3? looking at buying an older mpvi1 to do some bench work with, but I do alot of newer vehicles, and dont wanna buy a multi thousand dollar ECU.
    13,578
    I think one thread is good enough, but anyways.
    I still use the MPVI, had it since like 2012. I have no current worries with it for what I need it for. I can't use it on a ton of new new vehicles because I use older software on it and will not be upgrading this device to anything newer than what I have now.
    May 2023
    Delaware
    60
    Ok, do you need an mpvi1 to use with older versions? I still have 4.8.7, but cant get my mpvi3 to connect to it. Do i need an mpvi1? And if so, where can i get one?
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,279
    MPVI3 was introduced at the same time as v5.0 so 5.0 or newer is necessary for MPVI3.
    Nov 2006
    2,808
    I still have a MPVI1 Works fine.
    Anyone remember the Hptuners cables with DB9 serial ?
    Tuner at PCMofnc.com
