Results 1 to 6 of 6
Thread: TCM Lost communication. Am I missing something or is it just dead?
    I'll first tell what I have and then what it is doing. Let me know if I left something out or you need more information. This is my first swap so I'll do my best.
    I purchased a complete 6.0 LY6 with a 6L90e and transfer case out of a wrecked 2009 2500 HD. I heard the engine run, since it was wrecked it was not shown to drive or shift. I assumed since it was wrecked they were driving it when it happened. I also received the E38 ecm, the wiring harness, and the fuse panel. All accessories, minus MAF and air box also came with it. I installed the combo using the factory wiring harness and ECM into a 94 Z71. I cut the fuse panel out as I would not be using 90% of it. I assembled and put in a new panel with relays and fuses for fuel pump and engine power requirements. I read the ecm and made only the needed changes. Shut off VATS, turned off statrer checks, secondary o2, evap,and fuel pump relay settings. None of those are in the old truck and would not be needed. The engine starts and runs fine, I am pretty happy with it. I don't recall ever seeing a TCM in the software though. On the first drive I could tell it was in limp mode. I read the codes with a reader i have, not the scanner. I got a TCM and BCM lost communication. I don't have a BCM so that is expected. Now on to finding the TCM problem.
    Here is what I have tested.
    I have verified the red (pin 4 I think) to have 12v both connected to TCM and not connected to the TCM with key on and off.
    I have verified the pink wire (pin 12 I believe) to have 12v both connected tot he TCM and Not connected with only the key on.
    Testing this connected seemed important as once the TCM pulls power it should maintain good power supply.
    I have verified black wire (pin 5) is a good ground
    I have tested both the GM LAN wires from ECM to the trans and from the trans to the body connector are good.
    I have tested the serial wake line is good. no voltage applied on it's own.
    I have my OBD port connected to the GM LAN wires that come from the trans to the old connector that used to go to the BCM. I have cut off that connector and used those lines. So from what I can tell it goes from OBD port to trans, from trans to ECM. I have good communication to the ECM. This tells me the connector is at least in there that well. I have cleaned and made sure it is in all the way.
    I have read somewhere that I would need a 120ohm resistor ont he GM LAN line that used to go to the BCM. I put that on, no change.
    I also read that the wake line should have voltage, supplied by the BCM which I don't have, I applied 12v to that line and no change.
    Does anyone know of anything else I could be missing or is it possible that TCM is just bad?
    Any help or advice is always appreciated.
    Thanks.
    Tuner Guy With A Chevy's Avatar
    Aug 2023
    Corpus Christi, TX
    184
    I would try the seeing if another vehicle recognizes the tcm
    7,648
    Quote Originally Posted by Guy With A Chevy View Post
    That would be really difficult, seeing as the 6L's TCM is built into the valve body.
    Aug 2023
    Corpus Christi, TX
    184
    Ouch
    Just to post a resolution.
    The issue was the TEHCM. I ordered a reman from Street Smart. Got it installed and the transmission connected and is shifting fine now. It could use a shift tune, but that's for another time.
    Advanced Tuner PGA2B's Avatar
    Nov 2004
    St. Louis, MO
    474
    Take a look at the Bluecat Trans Tool. That will get you going.
    https://forum.hptuners.com/showthrea...Table-Software
    2013 OBM A6 CTS-V Coupe
    Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
    2006 Black Raven STS-V (Traded In)
    Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
