Results 1 to 8 of 8
Thread: 2009 G8GT Manual Conversion TR6060
    Tuner in Training BigDaddyG8's Avatar
    May 2019
    Peoples Republic of California
    32
    So I have read a lot of posts regarding this.
    I cannot get Segment Swapper to work for any Stock 2009 year file that I download. What am I doing wrong?
    I have my tune file open then i open the compare file .... I can see both files but the swapper is grey......
    The end goal is to have MY program modified with a manual trans profile. I have tried deleting the TCM module.... but no go.
    Any help is appreciated.
    I just don't wanna brick my ECM.
    John
    13,565
    If the OS's aren't the same, then the segment swapper usually never works.
    And I've never had the auto to manual segment swap work that good even on the older computers. We always start with a manual file if that is what we need.
    May 2019
    32
    Thanks for answering up I appreciate it...
    So does that mean just copy the same parameters from a manual car file and delete the TCM file?
    7,643
    The only way to make the ECM work like a manual trans ECM is to reprogram it with a real manual trans operating system. HP Tuners can't do that on a Gen 4, it has to be done using the GM tools.
    Nov 2006
    2,742
    You might have the best luck switching to a G8 GXP manual file. They only made 2000 GXP's and the manuals were even more rare. I know I did a Manual one at one point. Maybe I can find the file.
    Tuner at PCMofnc.com
    7,643
    6G2EP57W99L310255 is a manual trans G8 GXP. The file for that VIN requires ECM service number 12625455.
    May 2019
    32
    Thank you Blind Squirrel. It is much appreciated.
    May 2019
    32
    That would be awesome thanks!!!
