Greetings,
I'm looking for a little help specific to my setup. I put an LS3 in my truck (NBS Silverado). It's running the cable throttle body with IAC. It's this engine: https://blueprintengines.com/collect...a368a5fe&_ss=c
So, it runs and drives pretty good. My only issue at this point is how it starts. Whether cold or hot it seems like it doesn't want to start/remain running. If I crank it it will catch and attempt to run, but at a reduced rpm (450 or so). It's really chugging along and struggling. It does this for about 10 seconds (if it can stay running this whole time- sometimes it does, sometimes it doesn't). At about the 10 or 12 second mark it revs up to about 1500 and then settles into a nice idle at around 775. Idles very well after this and runs/drives fine. While watching the datalog it seems like it is the ignition timing that causes the jump to 1500. The IAC seems to be the same (roughly) throughout this whole scenario. At about the 10 or 12 second mark it advances the timing and then idles up and is normal. Additionally, if I give it just a little gas while cranking it fires right up and jumps to about 1500 rpms. If I then let off the throttle slowly it will settle into an idle and run fine after that. I've not watched the timing while doing this type of start. Here's the tune and a log showing a few of these starts- a couple where it stays running and settles into a nice idle and a couple where it dies during the 10 seconds. It seems like the timing is consistently around the 4-6 mark when it is doing this chugging and then after it throws some timing at it the idle picks up and it runs fine.
Thanks for the help!
