Results 1 to 4 of 4
Thread: CT4 10l80 lowering torque reduction
    Jun 2023
    1
    Hello, I would like to pull some torque reduction/timing pull out of my shifts, without eliminating upshift torque reduction completely. Disabling it completely is easy, but I am trying to wrap my head around the desired output torque factor table. I haven't found any info about this setup yet, only the previous 6 and 8 speeds. I am assuming this is my only table to modify (1 table per shift, then sections for normal, special 1 and special 2). Anyone have any insight? select the whole table and go up or down ~15%? Thanks
    Oct 2021
    china sz
    1
    CT4 10l80 降低扭矩
    Do you use this form? [TCM] 15403 Maybe this will work for you, can you share your stock file and I can take a look at it for you.
    Mar 2009
    Andover, MN
    457
    are these response's spam?
