Results 1 to 8 of 8
Thread: 2016 F150 3.5 ecoboost powermax turbo Need help
    Aug 2023
    3
    been sucking at tuning this truck. coming from tuning hondas prior im having trouble with this truck
    mods
    powermax turbos with high flow adaptors
    full race manifolds
    stainless works catted y pipe
    full exhaust
    turbosmart BOV
    i can get it to have lots of power on the hit but boost falls off and flattens out.
    8-23-2023 smooth out more tq Popcorn lambda changed.hpt8-23-2023 smooth out more tq Popcorn lambda changed.hpt
    Need a log. I suspect you need to increase your LSPI hi. Pretty rich too at .75 lambda
    Aug 2023
    3
    Here is a LOG FILE and updated tune. im still getting only 30 percent throttle at just about full throttle. i cant seem to find the wall im hitting, also in vcm i cant seem to find the right channels ether
    New tune 9-11 plus video current.hptupdated log file 9-11.hpl
    Sep 2023
    anyupdates? about to use same turbos, curious what youve found
    Increase LSPI HI only. Leave LSPI nominal and low stock. Only add in the 100 and 120 rows 2500 rpm up. Add .1 or .15 at a time until desired boost is reached. You are commanding stock boost levels. Adding to nominal and low will increase boost when lower octane fuels are used. Don't do that. As long as your OAR is -1 boost will remain the same could also be +1 depending on year. If when knock occurs OAR is reduced as well as reducing max boost levels. Also add more to your channels such as all the sources, (fuel, spark, torque, torque max). This is how you figure out what limiter needs to be changed when you hit one. add OAR too.
    Jun 2019
    Wisconsin
    297
    Edit - wrong thread
    Aug 2023
    3
    Thanks for the help i updated alot of things and the vcm scanner with more information.. seems to be hitting turbo limits also injector limits.
    log 3 more driver demand.hpl93 octane correct 10 percent TQ go to.hpt
    Mar 2015
    5
    Anyone has done the tuning for PowerMax turbo here?
    Euro tuner, turbocharger supplier.
