I have a 2019 GMC sierra with the upgraded e90 ecu from hp tuners and have purchased the 8 credits but I am not having luck on finding info on how to disable DOD.
Post the tune and we can take a look to see if it's under lean/fuel savings tab.
It is usually possible to disable it even if you have to do it by cylinder. You may have to go around more to get it done if hpt doesn't want to add in the tables that were left out of some of the calibrations as some have the tables and some don't, but that would require user defined access and talking to Will_974 on here.
~Greg Huggins~
Im not equipped to work on the E90 ECMs....
I can only currently support E92/A ECMs
If someone has a Binary file for a E90 ecm, i'd be willing to try to locate such tables.
but without a reference Binary to de-compile and locate with it is very much shooting in the dark.
Sorry, I thought you could do some of these. Well, still hope either way. Kind of long way, but would it be possible for someone to send you their ecm for de-compiling while they were doing the cam swap for instance?
~Greg Huggins~
If any one wants that service, they can PM me, and i'll discuss it and the limitations with them.
