Defining constant values/tables
Hello, I am trying to tune my Dodge Caliber and have some issues with Mass Airflow inside logs, It logs 0.0-0.3g/s which is incorrect and I assume that it's a calculated value because I have only a MAP sensor. In order to calculate the correct value I need to provide a VE table, which is defined in the ECU (PRatio/RPM) but it's impossible to define constant values in VCM Scanner.
Can you please add this functionality? Also, it will be nice to have a "condition statement" in defined formulas, I have 3 VE tables depending on the Throttle position.
If you want them to add the functionality you should probably open a ticket for that. I know they read the forums but the forums are more for community support, not for actual feature requests from the HP Tuners team.
Not a complaint, just hoping it can help you get the attention you want.
