Thread: Safe 4l60e Torque management settings with stock 6.0L LQ4
    Jul 2023
    6
    I have been trying to tune my stock 6.0L lq4 and 4l60e. I want to make my 4l60 last as long as possible and I haven't changed any TM settings. By default the abuse mode seems to be disabled and I am confused whether this means I have been driving with 0 transmission torque management. I recently removed the engine torque management and it is no longer pulling timing for shifts. Does anyone know what settings i should be using to make my 4l60 last? I will be replacing it with a built one in the future but until that is ready I want to try and make this one last. Here is my tune right now, Engine Tuning + shift kms.hpt
    Advanced Tuner Matt Vardaman's Avatar
    Mar 2021
    207
    I replied on the Gen 3 post, and gave you a file to use as compare file.
    2001 Silverado 5.3 - 209/217 cam, GT45 Turbo on 7lbs, Aem x-series wideband, 50lb/hr flex fuel injectors, on E85 with content sensor
    1999 Silverado 6.0/4L80E Summit Stage one camshaft, 317 heads (replaced cast iron)
    Sep 2023
    Were you able to correct your issue using this information?
    Jul 2023
    6
    Yes, I got my torque management working properly after reading the replies on my other post https://forum.hptuners.com/showthrea...0e-TM-settings
