Results 1 to 3 of 3
Thread: Spark issue at launch on drag strip
    Aug 2016
    Swansea Wales UK
    186
    Hi all, i've been looking through older logs and looking at my slight slow 0-60ft times compared too my old rover/buick engine set up and noticed a large dip in the spark as i launch at 2000 rpm. i was wondering if you have any suggestion before i take it on it's next trip, thanks John
    Gen3 L59/4L60E LS3 cast manifolds, Small Cam change, 2800 Convertor, MPVI, using MTX-L for wideband tuning
    13,576
    Turn off burst knock, that can yank a bunch of timing when you stab the throttle.
    Set the enable delta cyl air table to 7.900.
    Turn off brake torque mngt in the system options too.
    Aug 2016
    Swansea Wales UK
    186
    Many thanks for the reply, i will get those tuned in, John
