Originally Posted by
leomio
The vehicle was programmed to the factory calibration with GM MDI 2 and my VIN was purchased from GM and installed on the new, refurbished ECU, immobilizer and crank relearn done and then the custom tune for my modifications from saved files was uploaded to the new ECU. When I call, I'll have to ask if the service numbers are the same. Aside from the Service Vehicle Soon error at start-up, the car runs just as before with no hiccups, minus still having the Safe Mode issue.
My tuner did state that the operating systems were different from my original ECU to the new ECU ... the original being programmed to "Crank" signal whereas the new one from the 5.3L ECU was "Frequency" signal. When my tuner used the original "Crank" setting, the Service Vehicle Soon error didn't pop up, but the RPM tach didn't work. When he switched it to "Frequency", the tach works as it should, but the SVS error pops up at every start up.
