Results 1 to 4 of 4
Thread: Timing and advance for heavy truck
    Mar 2023
    18
    Hello everyone,
    I have an 83 Chevrolet C30 dually with an SM465 4 speed manual and Dana 70 rear end with 4.11 gears. In it is a 2004 5.3 from a Tahoe with the flex fuel injectors ad a returnless fuel rail. Other than that its all stock all the way to the air filter assembly. It's a heavy vehicle and I've been using the HP Tuners repository to compare timing tables from 2500 suburbans and pickups to help get me where i need to be as far as trying to make changes where necessary to compensate for the heavy weight. If i post my recent tune would anyone mind checking it out just to ensure that i have made the necessary changes? The truck is low geared so it does not see interstate use and very little highway use. Maximum i would have the truck up to is around 60-65 mph. But i will use it for pulling and it needs to be correct.
    8.25.Changes.new.plus.old.revised.hpt
    Thank you in advanced for any and all help
    Dec 2019
    MS
    504
    What fuel octane? What Spark Plugs?
    Mar 2023
    18
    I'm running mid grade 95 octane and the factory AC Delco spark plugs
    Nov 2017
    1,050
    Sounds like OP is likely in a non North America location so "mid grade 95" is likely US 89 or so.
