Results 1 to 7 of 7
Thread: bricked ecm
    Tuner in Training hitmix300's Avatar
    Jun 2015
    detroit
    20
    bricked ecm
    was flashing a 2014 f150 today with a 5.0 and it failed. afterwards the motor will not start. i had a ford ids handy and it states the pcm is unprogrammed. i tried to write entire with hp tuners but it fails everytime. is there any old tricks in the book to try and get this pcm back to life or am i stuck with using ids and a vbf file?
    Little update
    It appears to fail around 40 percent and the dash gauges seem to flicker. Is this a loss of power or am I not staying in key on power? It seems like something is causing the truck to reset. Not sure if there is a relay I can hotwire temporarily to recover.
    The software fails for transfer timeout
    Mar 2019
    352
    Put the battery on a charger and try again.
    Jun 2015
    detroit
    20
    Quote Originally Posted by B E N View Post
    Yeah I had it hooked up, thanks for the reply
    Anybody have any other suggestions
    2016 GenV 2SS twin turbo @20psi
    Jun 2015
    detroit
    20
    ok got it figured out. it sounds crazy but it worked, after i clicked "write" on write entire, i kept the key in crank for the whole 5 minutes and it took, everything is fine now..
    not sure what difference that made but, hey whatever
    hope this helps somebody down the road
    cheers
    Jan 2014
    SoCal
    1,582
    Quote Originally Posted by hitmix300 View Post
    cheers
    What it the world made you try that? Never heard of that trick. Link?
    Advanced Tuner skylinedan's Avatar
    Sep 2019
    Toledo Ohio
    243
    Sounds like the battery saver kept shutting it off, putting the key in the start position must have over rode it, and kept the power on through the rewrite.
    Jan 2014
    SoCal
    1,582
    Quote Originally Posted by skylinedan View Post
    I was thinking maybe during cranking it does not power up certain modules that may create communication issues when programming but that is a wild a** guess on my part.
