Results 1 to 5 of 5
Thread: 6r80 TCC ford ranger 3.2 sid 208
    Sep 2019
    11
    6r80 TCC lockup ford ranger 3.2
    Hello, I want to lock my tcc faster from 1st to 2nd and 3rd gear. On the TCC base map there is slip unlock and lock values for evey gear. How i make it lockup faster on the tcc base map? I increased lockup rate and lock after shift without sucess.
    Thanks.
    Sep 2019
    11
    Hello?
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    476
    When you mean lock faster do you mean the actual locking of the torque converter or do you mean lock it sooner in the RPM?s
    Sep 2019
    11
    To lock it sooner on RPM, i reduced desired slip. Increased lockup rate. Reduced tcc apply delay. Not sure on the TCC base map if I should reduce or increase slip and lock numbers.
    Jun 2012
    warrenton va
    476
    Post your file so I can take a look at it or PM it to me if you want. Either way is fine with me
