Results 1 to 7 of 7
Thread: 5r110 shifts very hard into 5th
    Sep 2023
    4
    i have a built trans in my 2008 6.4 from sam wyse it shifts extremely hard into 5th. To the point where it chirps the tires or slams you in your seat what would be the best way to soften it up id o not want to hurt the transmission in the long run. TIA.
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    490
    Shift pressure 3-5 reduce it in the areas you need it to stop slamming into gear.
    there is also the adaptives tab: Torque transfer, Initial slip and overall slip you can use.
    If your TC is engaged then you can try lock to lock shift table: reducing that will sometimes work.
    2003 Ford excursion 6.0 PSD
    No limit intake
    Straight pipe
    Studded
    EGR delete
    KC billet single plane compressor wheel
    Self Tuned
    XDP Regulated return
    RDP Fuel sump
    AEM progressive water meth
    Custom suspension air bags
    8" lift
    35" tires
    Sep 2023
    4
    I also tried to log the truck to find out exactly where my issue is but vcm scanner would not show the selected data.
    Jun 2012
    warrenton va
    490
    What PID?s are you scanning?
    Sep 2023
    4
    looking to watch fuel rail pressure, injection timing, inj pulse width.
    Jun 2012
    warrenton va
    490
    If your trying to fix a hard shift you should be scanning trans pressure, shift lag (this is going to be the one that shows you how fast the shift is happening), trans gear and I think it?s element E for TC lock up.
    Aug 2024
    2
    I have a 08 6.4 with a rebuilt 5r110w and a new tcm. I'm throwing codes for low circuit for c, d, and e shift solenoids. I have little movement in reverse and no movement in forward gears. When I hit the gas in d it revs out. Also no 4x4 ...???? SOS PLEASE HELP
