Results 1 to 2 of 2
Thread: 22' Jeep JT Ecodiesel Boost-MAP Issue
    Sep 2023
    1
    I have a 2022 Jeep Gladiator Ecodiesel.
    The "boost" reading in VCM scanner (or an OBDII monitor) will give artificially high readings. As bad as 30psi of boost with 15psi MAP. When this happens the vanes open up completely, resulting in zero power until it resets and follows the MAP readings.
    Even with what I assumed was the stock tune, I still have this issue.
    Am I missing something in the tune where the ECM is calculating boost incorrectly?
    Attached are a couple runs that illustrate what I'm describing.
    trial 1.hpl
    trial 2.hpl
    Can you post up your stock file plz? ive been wanting to compare the Newer engine against the older trucks for a while
