Page 9 of 9 FirstFirst ... 56789
Results 161 to 171 of 171
Thread: WB Maf Tuning ... Questions/Logs
  1. #161
    Feb 2006
    WPB, FL
    372
    Quote Originally Posted by EC_Tune
    The Gen IV motors have a different way of calculating AFR. You take all the OL tables and multiply them together to get the Commanded AFR.
    Please explain this better. I dont get it. I was looking at a friends values in his C6 Z06's PE table and the values didn't make sense to me. Perhaps this is why?
    98 Z28 370 LQ9 w/ TH350, FTI 4800 Stall, OLSD, NW90 TB, 80# Motron Inj, AFR 225's, 231/231 .624/.624 114, Mamofied FAST 90 Intake, PT88 Front Mount w/ 4" DP dumped before the Strange S60 w/ a 3.73 gear
  2. #162
    Супер Модератор EC_Tune's Avatar
    Apr 2003
    Almost 2000 feet.
    7,876
    Sure:
    You take the Open Loop AFR table and multiply it with the IVT Gain table, etc. The final result is your Commanded AFR (or EQ ratio on the 06+ Vettes)
    That's why some tables (05 vettes in particular) have 10's in them and other tables have .xx in them. Multiply 10 by .1 and you get 1.0 (Stoch).
    Always Support Our Troops!
  3. #163
    Feb 2006
    WPB, FL
    372
    thanks
  4. #164
    Apr 2007
    Atlantic City, NJ
    33
    Great post guys,
    This read has helped me a great deal. Haven't used any of it yet, but just getting the theories in my head(cause I think too far into things at times)
    Seems like things went well for you Howie, let us know how she runs at the track for you.
    Dave
    2002 T/A Firehawk : bilstein/eibach package, auburn
    TSP 404 Iron Long block with PRC stage 3 6.0L heads, Texas Giant cam, Fast90, NW90, Kooks 1-7/8", Kooks ORY, Magnaflow/cutout, Spec 2+, Spec Billet Flywheel, Racetronix 37# injectors
    Strano Springs, Koni Adjustables
    BMR: Q Arm, boxed LCA, PHR, STB.
  5. #165
    Not A Tuner
    Oct 2006
    977
    Quote Originally Posted by Arcolog
    Great post guys,
    Dave
    Check out my track day from wednesday......
    http://www.hptuners.com/forum/showthread.php?t=11655
    DH
  6. #166
    Advanced Tuner domestic rice's Avatar
    Dec 2006
    MB SC
    494
    When in OLSD what should be used to lean out WOT. My WOT afr is high 10's low 11's. I have the ve good for part throttle. When I tried to change the VE at the 100 cell, as well and the PE, but neither one really make much difference in my afr.
    99Z A4 w/ SS LT's, h/f cats, magnaflow catback, port/polish t/b, egr deleted, ls6 intake, lid, 3.73's, hpt, performabuilt level 1 tranny, 3600 stall, Stage 2.5 (5.3 heads), Torquer 2 cam, 42# reworked injectors, TR6 plugs.
    2007 Avalanche LTZ - Catback and Eibach springs
  7. #167
    Jul 2004
    1,579
    Quote Originally Posted by domestic rice
    Log what the Commanded AFR and Wideband AFR, plot the AFR Error % on a histogram with RPM (x rows) vs MAP (y colunms) and multiply your VE Table by that correction factor. Set and leave the PE Table to command 12.8 (1.142 for a stoich value of 14.62, 1.148 for a stoich value of 14.68) until the VE Table is correct. Never modify the PE Table to adjust for overly rich/lean conditions, unless the Commanded AFR matches the Actual AFR (with 1%, or 0.5% lean and 0.5% rich from the target AFR).
    Chances are you are not in the 100 kPa rows, but rather the 95kPa or worse the 90kPa rows. Use the histograms, they really help in this situation.
  8. #168
    Advanced Tuner Timonator's Avatar
    NW,Il
    206
    Howie,I've been reading this long thread and I have a couple of questions.
    1:back on post 83 you said you were going to start MAF tuning,when I look at your scan on the histogram you still had a couple of cells that were as rich as -9.Is this acceptable?
    2:When you copied the values from the histogram did you use the average numbers or the last numbers?
  9. #169
    NW,Il
    206
    The reason I'm asking is because I've been trying to get my VE table close to 0 for about a month now.I've been using the "A" numbers from the histogram.Here's where I'm at:
  10. #170
    Not A Tuner
    Oct 2006
    977
    Quote Originally Posted by Timonator
    Tim
    1. Its been awhile since I did that VE tuning but there always seems to be a cell that may read hi or low on any given log. Also it may only have been a single hit (you could check that)
    2. Definately its the AVERAGE
    Good luck.......
    DH
  11. #171
    NW,Il
    206
