Page 2 of 7 FirstFirst 123456 ... LastLast
Results 21 to 40 of 140
Thread: anyone have a minute to give input?
  1. #21
    13,565
    I'm curious what his key on engine off MAP kpa reading is. If he it at seal level it should be right at 100ish. Not like 105-110 or whatever.
  2. #22
    Tuner dooglestien's Avatar
    Sep 2023
    Sunshine coast BC canada
    71
    All I did was take the numbers from efi source website and put them in as they read on the site, saved the tune and wrote entire. probably just need to write segment I am assuming next time. the truck also has only one 02 sensor just after the turbo. the driver side is grafted into that wire and not operable. closed loop i think its called? worth mentioning I figured.
  3. #23
    Sep 2023
    71
    I am right at sea level, I show zero koeo
  4. #24
    Mar 2022
    Indiana
    2,945
    Alright here.
  5. #25
    Sep 2023
    71
    I have dinner at the house, I will be in the shop in a half hour and give this one a go
  6. #26
    7,648
    Your KOEO MAP should be reading actual uncorrected baro, which should be around 100-101 kPa for sea level. Please do not even log 'vacuum' in kPa, it will only make this even more confusing for you. MAP reads an absolute pressure, relative to a perfect vacuum (0 kPa MAP is less than what's in the void of interstellar space). If you're logging 'vacuum' that reads zero when equal to normal atmo, or 1 bar, or ~101kPa at sea level.
  7. #27
    Sep 2023
    71
    Alright here.
    sorry man, Spelled your name wrong. well that went really well. finally a smile. I got a few blocks away and figured I should stop and have a look to see if there was any suspicious activity and I have some crankcase pressure. enough to shove the dipstick back a half inch and spray that side of the engine. i know in the diesel world this aint good but im hoping maybe my crankcase vent is plugged or something. truck felt pretty strong and I was nowhere near all in.
  8. #28
    Sep 2023
    71
    I apologize mr squirrel. I have no clue on how to correct this. I looked at the map sensor values and was able to switch to a few different ones, I selected psi thinking that will only measure positive pressure. is that helpful? again, I am by no means a tuner and do appreciate the input
  9. #29
    7,648
    It may be an oddity of the 2-bar MAP channel that it doesn't read actual baro at KOEO. Think I have seen that come up before.
  10. #30
    Mar 2022
    Indiana
    2,945
    There's a problem with the wideband flatlining at 0.5, but I was able to filter that out. I've never logged before it's come up, but it looks like it's from the sensor warmup cycle. Just FYI.
    Next log go for a longer drive and get into the throttle a little more. Do a stair-step with the pedal. 1/4 and hold for 5 sec, 1/2 hold. Repeat a bunch of those. Do sets of long span full range pedal movements. Also, a fair amount of normal driving.
    Keep an eye on the wideband. If you're coming up on 0.9 lambda in boost let off.
    Start logging cylinder airmass (g) and Volumetric Efficiency Airflow (g/s). Remove channels that have to do with the MAF.
  11. #31
    Sep 2023
    71
    hell with work, we had truck shit to do. haha. certainly getting better! I forgot to add the cylinder airmass but have done that now. my son drove the second half so I could command 4th gear (another issue in itself). put some temp breathers in and seems to be breathing fine now. I cannot find the other sensor channel to upload, will keep looking. the afr gauge is switched now to Lambda and it definitely dips below.8 if your into it. seems to be fairly consistent at mid to part throttle over 1.0
  12. #32
    Mar 2022
    Indiana
    2,945
    Next one. Get into it a little more.
  13. #33
    Mar 2022
    Indiana
    2,945
    Here use this one. I had a dumbass moment about the injector offset...
  14. #34
    Sep 2023
    71
    I loaded that accidental one in and ran it, haha. didn't see your last post till now. not sure if these logs will be of any use but here they are. Feels pretty strong, seeing about 6psi max on the boost gauge. enough to blow the dipstick out again, I need to put a spring on it. Let me know if I should load up that newest version or if you want to have a look first. I cant thank you enough.
  15. #35
    Sep 2023
    71
    Yeah I'm going to need you to log the newest version. Shouldn't be much of a change overall, but I'd like to get it right.
    Sounds good I will load it up tommorow and run the truck. Should I try another segment swap on the trans to see if I can get 4th gear working? It engages when I command with vcm scanner, just not by itself.
  16. #36
    Mar 2022
    Indiana
    2,945
    It doesn't shift into 4th at all or just WOT?
  17. #37
    Sep 2023
    71
    At all. Unless I use the laptop.
  18. #38
    Mar 2022
    Indiana
    2,945
    Gear ratio and tire size? Aftermarket stall?
  19. #39
    Sep 2023
    71
    30.6" tire, 3:73 ratio stock stall.
  20. #40
    Mar 2022
    Indiana
    2,945
    Next one.
