O2 Sensor Heater Circuit Failure. I've been trying to deal with this issue for a while and I just can't seem to resolve it.
1. The O2 sensors show about 10 ohms on the same color wires.
2. I verified that there is 12V on those wires when the ignition is turned to ON (not running but PCM getting power and AC is switched on).
The harness I got, unfortunately, doesn't have connectors for the rear O2 sensors (which really sucks). Thinking of adding them.
Does anyone know where I can get additional pins for the PCM connector so I can run my own O2 sensor connectors?
Does anyone have any idea why the circuit thinks it is failing? The fact that I get heater power would seem to indicate that the PCM driver is OK but I am just not sure.
